 Innleggets emne: Nye: Mikado Logo 800 Xxtreme Combo
InnleggSkrevet: Man Des 05, 2011 8:46 pm
Nokon videoer!
http://www.youtube.com/watch?v=RRImcWaV ... _embedded#!
http://www.youtube.com/watch?v=tHW-YKCw ... r_embedded
Technical Data
Extreme 3D helicopter for 700 - 800 mm rotor blades
Suitable for 14S lipo batteries
Very rigid and light carbon chassis
New mounting system for batteries for optimal determination of CG and quick change of batteries
New rotor head design with 12 mm hollow spindle and 23 mm thrust bearings
Hollow 14 mm main rotor shaft
Herringbone main gear, 175 teeth, module 1
Tail torque tube drive with large bevel gears
6 mm tail shaft
Specification
Rotor diameter - 1,80m
Rotor blades - 813mm EDGE
RTF weight - ca. 6kg
recommended batterie - 2 x 7S LiPo 5000
Main gear ratio - 9,21 - 10,29 (Pinion 17-19 teeth)
Main Gear size - 175 teeth Module 1
Roy Inge Mjell
Eflight Nano cpx
Compass 7hv "Brain"
TT Raptor G4.1 Vbar 5.3 TT100
PA AddictionX
PA Katana MX
Aeroworks Yak 54 55dle
 Innleggets emne: Re: Nye: Mikado Logo 800 Xxtreme Combo
InnleggSkrevet: Man Des 05, 2011 11:25 pm
Ser ut som et veldig fint og stabilt helikopter. Er nok også veldig kjekt å fly grunnet størrelsen, da kan en fly stort på himmelen. Er litt i overkant på vekta, men så er det jo stort også.
