639603112_3_Big.jpg [ 21.69 KiB | Vist 20382 ganger ]
6ch-rc-fa-18-electric-ducted-fan-fighter-jet-rtf-24ghz.jpg [ 38.36 KiB | Vist 20382 ganger ]
Er på jakkt etter eit nytt jet fly og etter laaaang tid har eg funne nåke som kan vere av interesse.
Legger ut infoen som står om flyet.
Virker dette som eit fly eg kan vere "stolt" av å eige å som kan vere ei bra investering for ein som liker jet?
6CH RC FA 18 Electric Ducted Fan Fighter Jet RTF 2,4ghz
Specification:
Wingspan: 1010mm (40 inch)
Overall Length: 1500mm (60 inch)
Flying Weight: Approx 2000g (70.5 oz)
Drive System: Powerful Brushless Inrunner motor with 90mm electric ducted fans
Servo: 10pcs servo (3 Servos for Retracts)
ESC: 70A Brushless Speed Controller
Battery:18.5 Volt 3700mAh 5 cell 25C Lithium Polymer Battery
Control system: 2.4Ghz 6 Channel Transmitter and Receiver
Feature:
6 Channel Full Function Radio Controlled
Speed Over 130mph
New Twin Functional Rudders!
Improved Steerable Nose Gear Design!
Improved Design with Carbon Main Spars for Aggresive Pilots!
NEW 90mm Composite Fan Stronger & Lighter w/ Metal Spinner!
NEW Super Powerful Inrunner Brushless Motor!
Scale mechanical retractable gear system!
Approximately 15 minutes flight time on each charge
All spare parts and accessories are available
Package Include:
Airplane (90% assembled)
6 Channel PPM/FM Transmitter and Receiver (8AA Batteries Required)
High Quality Rechargeable Lithium Polymer Battery
English Manual
Requires Balance Charger to charge 18.5V Li-Po Battery NOT included
